KLS Martin - LIMAX
by KLS Martin
With the launch of the new diode-pumped Nd:YAG laser Limax®, surgeons have a laser system at their disposal which offers a triple advantage, combining the excellent beam quality of solid state lasers with an extremely high output power for faster interventions and a wavelength specially optimized for use on parenchymal tissue. The use of lasers with a wavelength of 1,318 nm has gained more and more ground in recent years, especially for the resection of multiple metastases. The optimal coefficients of absorption in both water and hemoglobin – exclusively attainable with the 1,318-nm wavelength – are just perfectly suited for cutting, coagulating and sealing parenchymal tissue. Apart from its clinical advantages, this new laser is a great economic solution as well. It not only saves you a lot of money on consumables, but also boosts the number of patients eligible for laser therapy.
[list] [*] Greatest possible preservation of healthy tissue [*] Maximum precision – even the most difficult localizations can be treated [*] Flexible, yet mechanically strong coagulation zones allow for visceral pleura sutures for increased safety [*] Dry (hemorrhage-free) and fistula-tight resection surfaces [*] Intervention can be repeated in case of recidivation [*] Significantly increased life expectancy with almost no loss in the quality of life [/list]
Laser Type | Nd:Yag |
Height | 107 cm |
Length | 59 cm |
Weight | 120 kg |
Wavelength | 1318 nm |
Width | 50 cm |
