KLS Martin - diomax
by KLS Martin
The “all-rounder” for advanced laser surgery
With the diomax® diode laser, KLS Martin offers you a system with a wide range of application, from outpatient practices to endoscopic high-tech operating rooms. The diomax® is very easy to use and puts you in control of a laser beam with physical properties that satisfy the highest demands. This makes it a true all-rounder for state-of-the-art surgery.
-Serge_Mix
5 years ago
status code 1005
power-on test failed and "status code 1005" displayed - could anybody tell me about this codes?Reply
-Amineamuos
6 years ago
Erreur ergot
ergot erreur on chanel monopolar ?Reply
[list]    [*] 980-nm wavelength for high absorption in hemoglobin and water    [*] Easy, straightforward handling    [*] Large color display for perfect parameter overview even in darkened ORs    [*] Top-notch beam quality for precise cutting    [*] 50 memory locations for standardized treatment programs    [*] Comprehensive range of application accessories for open as well as endoscopic or endoluminal surgery    [/list]
Laser TypeDiode
Wavelength980 nm
