Philips - Mx8000 Quad
by Philips
CT Scanner
In exams where image quality is paramount, the Mx8000 Quad provides high-resolution images with Isotropic Imaging capability. Its true 0.5 mm slice thickness delivers excellent image quality for critical areas such as I.A.C.s, P.E. studies, and joint examinations.
FORUMSView All (5)
-tough
Thu Jan 05 2017
slice count
how could I know the slice count and other information helpping me to know the condinoin of a used machine.
-tonyball
Sun Apr 10 2016
no scans with xray
I got the Host critical error message #1 even when the system boots up fine. xray tube, ebox and hv tank have been replaced already. I can run scans with the xray off.
anybody has an idea on what is happening?
-ICONPR
Fri Jan 24 2014
Communications Problems
Acq board never light the comm_en led. When I check the IRS Log in Procmon an error shows up: "AQC : Still waiting to RISC getting to ready state machine". I've change fiber optic cable, ACU, MCU Receiver, Transmitter and no change. Anyone can help me. Thanks.
Type (configuration)Multislice
Slices4
Weight2100 kg
Maximum Scan Range157 cm
Gantry (Max. Clearance) 70 cm
Image Display18 in flat
Patient Weight Capacity200 kg
