GE HealthCare - Advantx LCV+
by GE HealthCare
GE Advantx LCA Angiographic System provides state-of-the-art medical imaging for all general vascular and interventional procedures.
-winXRay777
Mon Dec 19 2016
ADVANTX LCV+
File system full/no utmpx entry/you must exec "login" level "shell
What dose it mean? What must i do?
-Treyes
Wed Jul 09 2014
2003 GE Advantx LCV+
can you give me an idea of what this system is worth (price range) on the use market? Thanks
SERVICE COMPANIESView All Cath/Angio Companies
[list]    [*] LCV+ Floor Mounted Three-Axis Positioner Design Provides Maximum Positioning Flexibility and Excellent Patient Access in All Views. With Three Motor Driven Axes, the Innovative Advantx LCV+ Positioner Makes it Easy to Achieve Even the Most Complex Angulations    [*] Advantx 100 kW Three-Phase Power Unit    [*] 32cm (12 in.) Four Fields-of View HX Image Intensifier Allows the Operator to Match the Field Size to the Relevant Anatomy, and is Well Suited for Both Cardiac and Angio Applications    [*] MX-150 Water Cooled X-Ray Tube with Pulsed Fluoroscopy Provides Excellent Cardiovascular Imaging Capabilities. The Tube's 1.95 MHU Heat Capacity Along with a High Heat Dissipation Rate Minimizes the Need for Heat-cooling Delays, Even with Aggressive Techniques    [*] Omega IV Angio Table with 4-Way Mechanical Float and Motorized Longitudinal 2-Way Travel Allows Easy Patient Positioning and Total body Coverage for 6 Foot 4 Inch Patient    [*] Table Side System Control Mounted to the Table Side to Provide Fingertip Access to Common Imaging Functions    [*] Vascular SRI Collimator Combines Both Rectangular and Circular Collimators    [*] Autopositioner Increases Productivity Through Easy Table Side Storage and Access of Commonly Used Positions. This Option Allows Nine Different Operators to Store Eight Unique Positions for a Total of Seventy-Two Stored Positions    [*] DLX - Cardiac/Angio Digital System is a Fully Integrated Imaging Subsystem that Meets Key Cardiovascular Imaging Demands Through Extensive Storage and Advanced Post Processing, Display and Quantitative Analysis Capabilities. The DLX-Digital System Utilizes a UNIX Architecture and Windows-like Environment Ensuring Upgradeability and Ease of Use    [*] DLX High Speed Combo Gateway Provides Both Cardiac and DICOM ATM (150 Mbps) Output and Angio DICOM Fast Ethernet (100 Mbps) Output for Acquisitions From the DLX Digital System    [*] Two Monitors on and Ceiling Mounted Overhead Suspension/Boom    [/list]
