Mindray - Passport V
Passport V was designed with you, the clinician, in mind.Passport V is Mindray's latest addition to a long line of portable patient monitors designed to meet the needs of caregivers in a range of clinical areas. Passport V is built on a solid foundation of experience and knowledge. It follows a proven approach to acquisition and presentation of patient data, thereby delivering impressive reliability and performance. Like other products in its line, Passport V utilizes a straightforward, familiar interface so that the user’s experience is a positive one. It delivers just the right combination of simplicity and sophistication, offering a comprehensive feature-set in an uncomplicated, easy-to-learn manner.
Beyond that, this clever new monitor delivers just as much flexibility as you’ve come to rely on with our other patient monitors. Passport V is available in a variety of versions, depending on your capability and technology preferences. With a broad range of options, it is well-suited for most hospital departments.
Enhanced capability, more optional features and extraordinary value make Passport V a compelling alternative for any healthcare environment requiring continuous physiological monitoring.
FORUMSView All (6)
1Reply4 months ago | Co2 errors Co2 errors? Equipment: Passport V Reply |
1Reply4 months ago | CO2 error CO2 filter line Error? CO2 Hardware Error? Equipment: Passport V Reply |
1Reply3 years ago | parts - passport V Does anyone have a supply or source for parts? I'm looking for an LCD at the momentReply |
- The large 12.1” display is highly visible from most vantage points.
- ECG, NIBP, temperature, respiration and Masimo SET® motion-tolerant SpO2 as its standard configuration
- 96 hours of patient data is provided in a list or graphic trend format so you can easily review your patient’s history\
- Comprehensive calculations packages including both IV drug and hemodynamic data allow for quick and automated calculations. Titration tables and calculations can be printed to the internal recorder or a networked laser printer to satisfy long-term documentation needs.
- Remote View mode with 8-bed alarm notification enables clinicians to monitor multiple patients without leaving the bedside
- The innovative quick-release mount makes transport a bit easier. Remove the monitor from its wall mount or rolling stand using the one-touch mechanism and you’re ready for transport. No need to disconnect patient cables.
- Pair it with the Gas Module 3™ multi-gas analyzer to create a powerful, yet compact O.R. monitoring solution
Height | 28.5 cm |
Length | 14 cm |
Weight | 5 kg |
Printer | Integrated Thermal Printer |
Temperature Range | 0 to 40 °C |
Width | 30 cm |
