Bovie - Aaron 1250
by Bovie
The Aaron 1250, by Bovie®, features Cut, Blend, Coagulation, Fulguration, and Bipolar modes.
The Aaron 1250, by Bovie, features Cut, Blend, Coagulation, Fulguration, and Bipolar modes. Bovie incorporates automatic safety features into the Aaron 1250 like self-test circuits, audible tones, discreet outputs, isolated circuitry, and Bovie NEM™ (neutral electrode monitoring).                    The Aaron 1250 by Bovie is a multipurpose electrosurgical generator for use in the modern physician's office and surgi-center. It features both monopolar and bipolar functions to satisfy all of your surgical demands with safety, flexibility, reliability, and convenience.                    The Aaron 1250 incorporates 120 watts of cutting power and 90 watts of blended cutting. It also has two levels of coagulation, pinpoint (80 watts maximum power) and fulguration (40 watts maximum power), plus bipolar (30 watts maximum power).
FORUMSView All (11)
-JDeering@mmc
Thu Apr 08 2021
service manual
pm frequencyReply
-Erik Pasin
Sat Oct 07 2017
CAUTERIZE DOES NOT WORK
wE USE THIS TO CAUTERIZE DURING A NO SCALPEL VASECTOMY. THE CAUTERIZE PLUG DOES NOT STAY ONReply
-wlcbmt
Tue Dec 01 2015
c 19
cap smoked
Convenient Display Features          For your convenience, the power output of the Aaron 1250 is calibrated in watts with large, illuminated digital displays.                    The Aaron 1250 remembers its last used settings; so when you turn the unit on, it performs a safety system check and automatically powers up to those settings.                    Coagulation Modes          The Aaron 1250 offers two levels of coagulation: pinpoint and fulguration. Pinpoint coagulation provides precise control of bleeding in localized areas. Fulguration (spray) coagulation provides greater control of bleeding in highly vascular tissues over broad surface areas.                    Designed for Safety          Electrosurgical safety is a combination of good equipment design and safe surgical practices. The Aaron 1250, as part of this combination, represents state-of-the-art design using the latest in digital technology.
Height15.2 cm
Length 30.5 cm
Weight14 lbs
OutPut Frequency300 kHz -800khz
Output Power120 W Cut
Width26 cm
Output Power      Cut: 120 watts       Blend: 90 watts       Coagulation: 80 watts       Fulguration: 40 watts       Bipolar: 30 watts             Line Voltage      A1250: 120 VAC ± 10%      A1250-220: 220 VAC ± 10%            Line Frequency      50-60 Hz
