Ohio Medical - Aeros Moblvac III
by Ohio Medical
Moblvac III is a multipurpose portable suction unit.
It produces both constant and intermittent suction with vacuum and flow levels equaling that of wall suction. Moblvac III is packaged in a compact, durable, molded Polystyrene case. The heart of the Moblvac III is a fan cooled carbon rotary vane pump. Moblvac III is insulated to provide one of the quietest sounding suction pumps on the market today.
-rjBrouss77
Wed Mar 25 2015
Wiring Diagram
I have a MoblVac II model 5500-A that needs a button replacement. I found the button, however I am in need of a wiring diagram. Additionally, somehow the control switch for continuous and intermittent has been tampered with and nothing seems to be hooked up accordingly. All wires are numbered and each terminal is numbered on the switch. Nothing matches up, any help would be greatly appreciated.
[list]        [*] Multipurpose unit, constant & intermittent suction modes        [*] Allows for standardization, replaces 3 single function style units        [*] Quite operation        [*] Easy to clean and process for quick turnarounds        [*] Fan cooled pump, mechanical safety overflow trap and exhaust port filter        [/list]
Height28 in
Length 16 in
Weight35 lbs
Width14 in
Vacuum Range: up to 380mmHg
