FutureMed - ASTOTHERM PLUS
by FutureMed
The fastest and most economical of warmers, Astotherm Plus (AP220 and AP220S) is ready for use in under 60 seconds. As a result, patients can be supplied with warm transfusions and infusions rapidly. Asthotherm Plus 220 covers over 97% of clinically-relevant transfusion and infusion rates. From very low to rapid flow rates, all fluids reach the patient at the optimum temperature, efficiently heated and additionally backed up by the warmed ASTOLINE heated profile. No other dry warmer provides this benefit.
[list] [*] Fast, easy setup, requiring no special priming. Astotherm Plus warms up in less than a minute. [*] A visual temperature display lets you monitor fluid temperature. [*] Astotherm Plus has 3 independent safety alarms and a circuit shut-off to eliminate the risk of overheated fluid reaching the patient. [*] The economical Astotube extension set costs significantly less than disposable sets required for other fluid warmer, making it practical to provide the benefits of warmed fluids to more patients while savings hundreds or thousands of dollars each year. [*] Astotherm Plus can be disconnected from the IV line without interrupting the flow of fluids to the patient. [*] Astotherm's dry-heat surface is mess-free and can be wiped clean in seconds. [/list]
