STERIS - 6090
by STERIS
Surgical table
FORUMSView All (3)
-assaker
9 years ago
main board needed
Dear Sir i have ALM 5090 orhtopedic table and i have a problem with the main board #MTH 0190 02,
can you help me find it somewhere
thank you
-Denyers
11 years ago
Pump Motor Seize
FH Surgical, ALM, Steris, Gettinge --- 6090
Pressing an actuation on the Handcontrol - but only getting a clicking sound ??
Could be the motor has seized, do not "tap" it with a mallet, or bump/drop the table to the floor, the magnets are glued on and you could dislodge them. it will probably be a carbon build up in the motor, (strip and clean, replace the carbon brushes / bearings ) - record the position of the relay assembly wires, before stripping !!!
Not even getting a click - if the batteries are good ( look for the green light on the battery icon on the Handcontrol), then the relay is bad - (replace)
-NevilleT
14 years ago
Universis 6090
I have a universis 6090 which was in storage for over 12 months, the battery is now dead and the unit is at its lowest vertical travel.
I am unable to access the batteries, is there an override system to release the vertcal drive
nev
