Carestream - CS 9300
A low-dose, three-in-one solution designed for both ENT and dental imagingCombining true panoramic imaging, cone beam CT (CBCT) technology and optional cephalometric capabilities, the CS 9300 will make expanding your ENT and dental imaging services easy and affordable.
Featuring a range of fields of view and resolutions, the unit will be ideal for visualizing even the smallest middle ear structures – and all at a much lower dose than conventional CT exams, a benefit your patients are sure to appreciate.
FORUMSView All (4)
2Replies2 years ago | PM Checklist Does anyone have a PM checklist for Carestream - CS 9300? Reply |
0Replies8 years ago | How to delete 3D X-Ray before it is saved? In the middle of taking an 3D my patient moved, I stoped it from finishing the CBCT. What do you do to keep the partial x-ray from taken being saved? I exited out of everything and went back in and took another CBCT which turned out great. When I saved it the first one also downloaded and was saved. Reply |
0Replies9 years ago | Scan times need to be updated... Scan times are also 12 and 20 seconds for the standard scans. The new low dose options have exposure times at 3 & 3.7 seconds
Reply |
- Broad range of CBCT applications – such as paranasal sinus, temporal bone, dental implantology, trauma, and oral surgery -- enables expansion of dental and ENT services
- True panoramic and one-shot cephalometric technologies provide stable revenue stream and increased productivity
- Affordable, reliable equipment and low operating costs
- Broad range of isotropic resolutions (0.09 mm – 0.5 mm) and adjustable fields of view (ranging from 5 x 5 cm to 17 x 13.5 cm )ensure optimal image quality and dose for each exam
- Ultra high CBCT resolution (0.09 mm) delivers superior fine bony structure visualization of temporal bone and radicular structures
- CBCT radiation dose much lower than low-dose and standard conventional CT (MSCT) exams.
A system that works the way you do, and helps you support your referral base - Streamlined user interface, preset programs and face-to-face positioning make exams quick and simple
- DICOM conformance ensures easy integration with PACS, RIS, and printing systems
- Intuitive, easy-to-use imaging software with improved features for reviewing, reporting and sharing images with referring dentists and physicians
A trusted company, a proven product - Built on a proven CBCT platform with an installed base of over 3,000 units
- Broad range of Carestream equipment and professional services such equipment service agreements, site planning and DICOM integration services.
- One-stop shopping for digital imaging and IT solutions from a company with over a century of medical and dental imaging expertise
Multiple modalities. Attractive return on investment.
High cone beam CT image quality at low radiation dose
3D Modality
Sensor typeTFT
Scan modeContinuous and pulse
Scanning time12-28 seconds (+/- 10%)
Gray scale16384 - 16 bits
Voxel size (µm)90 to 500
Field of view (cm)5x5, 8x8, 10x5, 10x10, 17x6, 17x11, 17x13.5
Reconstruction timeLess than 2 minutes based on the recommended computer system configuration requirements
NEWSView All
Carestream Health Launches CS 9300 For Radiology Professionals
Low-dose, 3-in-1 System Designed for Otolaryngology (ENT) and Dental Imaging
ROCHESTER, N.Y., August 31> — Carestream Health has received US market clearance from the FDA and is now shipping worldwide the CS 9300 System, a high-quality cone beam CT (CBCT) and true panoramic imaging system for ENT and dent...
