Schiller - ARGUS LCM plus
by Schiller
The SCHILLER ARGUS LCM plus monitor -for the comprehensive vital data monitoring of adults, paediatrics andneonates. It is suitable for intra-hospital transport as well as in theward.
8RepliesWed Mar 03 2021 | Lines on the screen There are vertical white lines on the LCD screen. How can I fix this? Reply |
1ReplyWed Jan 09 2019 | Switches off while measuring BP Hello, When I start NIMBP the monitor. spontaneously switches off. Is there an easy way to fix this problem?Reply |
1ReplySat Jan 07 2017 | Unit won't power on two units When unit is plugged in there is a green light for line power. When I try to turn on the red LEDs above the parameter buttons flash red and then nothing. This is happening to two units. Couldn't find anything in the manual with this issue. Going to start with batteries but wanted to see if anyone had similar issues or other suggestions.
Thanks Reply |
[list] [*] Excellent price/performance ratio [*] Large, high resolution colour LCD [*] Light-weight and compact design [*] Simplified operation using direct function keys [*] Simultaneous 12-lead ECG [*] Up to 5 traces on screen [*] ECG in diagnostic quality [*] 12-channel print out [*] 3-traces printer [/list]
| Height | 290 mm |
| Length | 180 mm |
| Weight | 4.6 kg |
| Width | 275 mm |
[u]ECG[/u] Amplifier: >5 kV Leads: Simultaneous recording of up to 12 standard leads HR display: 20 – 250 beats/min. Automatic lead programme: Simultaneous display of up to 3 leads per page Sensitivity: 5/10/20/40 mm/mV, manually selectable Pacemaker detection: = 2 mV/ = 0.1 ms [u]Trends[/u] Memory: All data are stored for 24 hours Display: In tabular and graphic form Recording: Graphic representation possible [u]Respiration[/u] Measuring principle: Impedance method with 3-, 5- or 10-lead patient cable Measuring range: Apnoea, respiration rate: 0 - 200/min. [u]Temperature[/u] Amplifier: Fully insulated, defibrillation-protected, > 5 kV Measuring principle: Rectal, skin or ear Sensor: YSI 401 Measuring range: 15° C to 45° C Resolution: 0.1° C
