Schiller - ARGUS LCX
Convenient Vital Data Patient Monitoring - switch on and use it!With the new SCHILLER ARGUS LCX the size of the LCD has been maximized, while the monitor depth is minimized to 77 mm. The result is a concise delineation of complex patient analysis. This ultraflat and x-tremely user-friendly patient-monitor can be mounted easily on a wall or medical cart. The device has a capacity of 2 hours mains independent operation, which makes it an ideal multi-parameter monitor to be used for inhouse transportation.
FORUMSView All (7)
0Replies7 years ago | Maintenance/Repair My department is receiving the above mentioned brand of Patient Monitor with the same problem of not going through the program loading phase. What can be the problem and yet the power indicator is on?Thank You!SamuelReply |
1Reply7 years ago | Maintenance/Repair My department is receiving the above mentioned brand of Patient Monitor with the same problem of not going through the program loading phase. What can be the problem and yet the power indicator is on? Thank You! SamuelReply |
0Replies8 years ago | Schiller argus lcx configuration password Hello I need password for configuration menu or factory defaults Or service manual for argus lcx Please help Thanx in advance Reply |
Parameters: [list] [*] ECG: displayable leads I - V1 [*] Respiration [*] Pulse oximetry (SpO2) [*] Pulse rate [*] Temperature [*] Non-invasive blood pressure (oscillometric) [*] Two invasive blood pressure measurements [*] etCO2 main- or sidestream (optional) [/list] Features: [list] [*] Very large display - 307 x 230 mm (381 mm diagonal) [*] Built-in 3-channel thermal printer (optional) [*] Software update with USB stick [*] SD memory card [*] Trends: Standalone for 6 days, with central station for more than 15 days [*] Alarm history [*] No fan inside (noiseless operation) [*] The ultrafast and calibration-free etCO2 module can be installed later by the user. No technical changes necessary. Simply connect and use it. [*] Standby and transport modes [*] Nurse-call [/list]
