Schiller - ARGUS OXM plus
by Schiller
Pulse Oximeter
This portable Pulse Oximeter is configured as a bedside or portable unit, designed for hospital, transport and home use, for neonate, pediatricand adult patient applications. It is compact, light-weight and very easy to use, providing ultimate non-invasive oxygen saturation monitoring, pulse rate and trend data. The bright LCD and LED Combo Display provides great visibility of the numerical results as well as the plethysmographic waveform. The SCHILLER ARGUS OXM plus is equipped with the latest technology for enhanced signal quality indication during motion and low signal tonoise situations with accurate tracking of rapid changes in saturation and pulse rate.
-dindin
Wed Sep 05 2012
system error 1 & 2
hello,
How can I fix system error 1 &2       in schiller argus oxm plus
Thank you for your help
SERVICE COMPANIESView All Pulse Oximeter Companies
  • Compact bedside configuration
  • 72 hours data memory
  • Built-in rechargeable battery
  • Probe locking design
  • Audible and visual alarm
  • RS-232 output (Printer or Communication)
Height87 mm
Length 186 mm
Pulse Rate Range15-300 BPM
Weight2 kg
Memory72 hr
SpO2 Range0-100%
Width267 mm
