Medivators - CER Series
Compact Endoscope Reprocessor designed to quickly reprocess one or two immersible endoscopes per cycle. The CER features simple, push-button operation, and a large reprocessing basin for disinfecting any size endoscope (including EUS endoscopes), and a small footprint for countertop or mobile cart use. Reprocessor capabilities include a user-selectable wash cycle for endoscope cleaning, an alcohol purge port, and automated air drying of endoscope channels. A fully gasketed lid contains disinfectant vapors, and the CER's unique design self-disinfects internal fluid lines during every cycle. A two-stage water filtration system reduces particulate matter and provides certified bacteria-free water for endoscope rinsing. The CER includes heated disinfectant reservoir, water pre-filtration system, alcohol flushing tubing, accessory bag, and one set of water filters.
1Reply10 years ago | LCG Level Fail on CER-2 During the LCG phase, once the disinfectant fills the basin the LCG level fail alarm goes off. I've checked the disenfecant level and it's fine so I took the cover off the sensor after I drained the basin and manually lifted the floater portion up and the water did not stop so I'm guessing the water level sensor is broken? Is there anything else I should try? Reply |
[list] [*] Compact, cost-effective endoscope reprocessing featuring simple, push-button operation [*] Fast cycle time for quick endoscope turnaround [*] Individual endoscope channel connections ensure disinfectant and rinse water contact with all channels [*] Pre-programmed cycles for reprocessing cycle repeatability and consistency [*] CER-1 model disinfects one endoscope per cycle [*] CER-2 model disinfects up to two endoscopes per cycle [*] Gasket lid and sealed reservoir contain disinfectant vapors [*] Alcohol flush and air drying of endoscopes [*] Audible and visual alarms for reprocessing cycle deficiency [*] Assures patient and operator safety [*] Self-disinfects internal fluid lines during every cycle [*] Bacteria retentive two-stage water filtration system [*] Compatible with all current models of endoscopes, including those with elevator wire channels [*] For use with most FDA-cleared reusable high-level disinfectants [*] Vapor management system, disinfectant transfer pump, neutralization system and mobile cart optional [/list]
