Medline - BioCon-500
by Medline
SCANNER, BLADDER, ULTRASOUND, W/PRINTER
This portable, 3-D ultrasound device with pre-scan feature is a quick, safe and non-invasive way to measure bladder volume and post-void urinary retention. The pre-scan feature save times and increases accuracy. On-site printing with PC transfer helps the caregiver to quickly and easily document and track the resident's progress.    This Bladder Scanner benefits the residents by preserving dignity and reducing discomfort. The scanner benefits the facility by helping to improve resident care, reducing the frequency of catheterization, saving staff time, decreasing total expense, and reducing training time.
-Ron dauphin
12 years ago
inventory receiver
Our biocon 500 comes up maintenance mode when the unit is turned on.
What does this mean ?
Thanks
Ron
[list]  [*] Calculates results in less than five minutes.  [*] Helps to develop individualized toileting schedules based on each resident's bladder function pattern rather than at fixed times, such as every two hours, saving staff valuable time.  [*] Promotes staff efficiency and requires little training.  [*] Quick, safe and non- invasive way to measure bladder volume and post-void urinary retention.  [*] On-site printing with PC transfer helps the caregiver to quickly and easily document and track the resident's progress.  [/list]
[list]    Accuracy*: ±15%, ±15ml (0-999mL)        Dimension with W/T: 375(L) × 240(W) × 116(H)mm (2.86Kg)        Display: 5.6" STN LCD (320 × 240 pixels,16 gray levels)        Ultrasound Output: Maximum (ISPTA): =1mW/cm2        Parameters: Maximum (ISPPA): =10mW/cm2        Printer: Built-in (57mm paper width)        Volume: Range 0 - 999mL     Weight: 2.86 kg with the battery installed    [/list]
