Valleylab - ForceTriad
by Valleylab
The ForceTriad energy platform is a first-of-its kind integrated solution for open and laparoscopic electrosurgical procedures. This platform provides the operating room with one energy system for electrosurgical and tissue fusion needs and gives surgeons the ability to deliver precisely controlled energy and improved tissue effect. In the past, operating rooms needed separate pieces of equipment to achiever different tissue effects: monopolar, bipolar and vessel sealing. The ForceTriad combines all three into one easy-to-use platform, making setup simpler. It offers the surgeon a wide range of options, including electrosurgical cutting and coagulation, bipolar functionality and LigaSure tissue fusion.
4Replies2 months ago | REM fault will not clear, wrong return cable? Veterinary use We purchased a Valleylab Force Triad from Avante Surgical a couple months ago. Our requests for help to Avante have went unanswered. The patient return electrode is a stainless pad style, not a split pad style. With the split pad, I understand that the REM system is measuring resistance between the pads to determine if there is good patient contact prior to initiating power output, as a safety measure to reduce burns. With the solid pad, there can be no such measurement. I see different connection wires listed for solid pads vs split pads. It appears from pictures, that the wires for solid pads are simply a modified split pad cable that have had a resistor soldered in line on each monitoring wire, which would trick the REM system in to believing there is good patient contact. Is it a reasonable to believe that we have been shipped the wrong cord for our solid paddle. That is, a measurement of the resistance of each wire, to show less than 5 ohms, is indicative of a cable intended for a split paddle. Reply |
2Replies2 months ago | C on display screen I changed the screen and now there is a big C display screen I dont see anything online? Is there a way to get it off.Reply |
2Repliesa year ago | E274 forctraid When i turn the device on it display E274 host self error so i enter to service ==>diagnostic ==>self test I run self test and the RF generator fails So what can i do to solve this problem?Reply |
OutPut Frequency | 660 kHz Cut |
Height | 10 in |
Length | 20 in |
Weight | 30 lbs |
Width | 18 in |
Frequency
Cut: 660 Hz
Valleylab: 800 Hz
Coag: 940 Hz
Bipolar: 940 Hz
LigaSure: 440 Hz
Quality training is essential for the Biomedical profession, but it's often hard to find. BC Group is proud to endorse and recommend this new and innovative option for our industry.
