Bayer - Clinitek 100
by Bayer
Urine Analyzer
Designed for small to medium sized laboratories with standardized test procedures, the Clinitek 100 Urine Chemistry Analyzer eliminates variables that are sometimes associated with visual strip reading. The Clinitek 100 Urine Chemistry Analyzer gives you consistent results, test after test, and is fast and easy to use.    A semi-automated, single sample benchtop instrument for low-to-moderate uine testing. The Clinitek 100 Urine Chemistry Analyzer uses reflectance photometry to read SiemensMultistix 10 SG Reagent Strips to perform the following chemistries: bilirubin, blood, glucose, ketone, leukocytes, nitrite, pH, protein, specific gravity, and urobilinogen. In addition, the Clinitek 100 Urine Chemistry Analyzer will read new assays, such as hCG and microalbumin/creatinine. Test reults are displayed by an 8-line, 40-character LCD screen and recorded by an internal thermal printer. The system is user-friendly with visual operator prompts. All programming for the instrument is contained in a replacable Program Card. Up to 1000 sets of test results are stored in the none volatile memory. The system has options for bidirectional communication with a host computer and a form printer, as well as most 80-column parallel printers.
FORUMSView All (6)
-CathyB2017
Thu Oct 01 2020
Error Codes
I am getting the Error Code "Instrument Error" "Calibration Error" (Low) I know this is an old machine and I have tried to call tech support but of course that does not seem to be in existence anymore. The model is a 5772. Any ideas? I have cleaned it, unplugged it, made sure everything was plugged in correctly but I still get the same error.  i should have said it is a Clinitek 100 Model 5772
-N Gumb
Wed Sep 02 2015
comment for odd colors affecting results
What kind of canned comment can I add to our report when the urine is an odd color and affects the results of the Multi-stick?
-CARLTON
Fri May 24 2013
CAL ERROR
WORKING WITH A CLINITEK 100 AND ON POWER UP I AM GETTING A CAL ERROR LOW  523/103/205/85/285/111..  SIEMENS NO LONGER SUPPORTS ANYONE HAVE AN IDEA.
THANKS,
CIKNER@CPLLABS.COM
  • Semi-automate
  • 8-line, 40-character LCD screen
  • Internal thermal printer
  • Replaceable Program Card
  • Up to 1000 sets of results stored in non-volatile memory
