Toshiba - T.RAD Plus
by Toshiba
X-Ray Systems Made for Life
The T.RAD Plus series of radiographic systems for general-purpose radiography are available with multiple prepackaged configurations and more standard features to provide high-quality imaging, exam efficiency and excellent patient care.
FORUMSView All (4)
-Tesla.med
2 years ago
a problem with TOSHIB T-RAD PLUS both table and wall buckeys grid
hi everyone : the system working normally but there is a problem with heavy x-ray dose images like chest image .. the image is appearing to be less resolution ... when i take the table apart i noticed that the GRID motor not rotating .... and as so the wall buckey GRID not functioning ... i need a service manual for the high voltage generaton ( TG-6500-HS) .... so i can analyse the voltages .. and if anyone has any idea how could i RUN the GRID without the ENABLE command frome the generator .... OR if someone can support me withe the principle of the theorm of function of the GRID generally . thanks in advance ..Reply
-dr_jh_9746
3 years ago
t Rad Plus
Hello I need the manual for this X-RAY generator system please, i could not find it any where: T.RAD PLUS (TG-6500-HS) Thanx alot for your helpReply
3
-Tesla Imaging
8 years ago
TW-240 T Rad service manuals
Where can I find a services manuals for a T Rad plus systems
The versatile, elevating float-top table promotes precise positioning and maximum access to comfortably handle a diverse patient population.        [list]        [*] Wider table design and patient grips enhance patient comfort and confidence.        [*] Elevating table enables safe and easy patient loading and positioning.        [*] Sturdy table design handles high patient weight capacity.        [*] Simplified table design ensures access to patient on all sides.        [*] Easy floating motion accommodates even the most difficult projections.        [/list]
X-ray Generator Power Rating50 Kw ,65 or 80 kW generator
