Cincinnati Sub-Zero - 400 CE Hemotherm
by Cincinnati Sub-Zero
Cardiovascular Dual Reservoir Cooling/Heating Systemn provides precise blood temperature control without ice.
The quiet running system delivers reliable, effective blood temperature management control during cardiopulmonary by-pass and other related cardiovascular procedures.
FORUMSView All (3)
-Jenschro3
Invalid Date
Cleaning
Could you clean this machine with a non bleach alternative?Reply
-Poetry06
Invalid Date
Its Price
How much the price of this heater-cooler product?Reply
-Hanner
Invalid Date
hook up ports
Are perfusionists able to run normothermic patient oxygenator blood temp at same time as cold cardioplegia How many hookup ports are available on the Cincinnati Sub Zero 400 CE heater cooler?Reply
  • Mechanical refrigeration to replace messy, unmanageable ice
  • Independent heating and cooling reservoirs each with its own controller and temperature display
  • Self-checking microprocessor
  • Supplies water to a blood temperature exchanger/oxygenator or hyper-hypothermia blanket
  • Easy to use interface
Height32 in
Length 22 in
Width22
Water Temperature: 3° - 42°C (37.4° - 107.6°F)      Flow Rate: 246 GPH (flow-through Hansen fittings0
