MediWatch - Portascan+
A Truly Portable Real-Time Ultrasound Bladder ScannerUrologists, primary care physicians and nurses rely on accurate imaging of the bladder in order to determine the need for treatment. The Portascan+ has been designed for use by a variety of carers in a point-of-care environment where immediate, reliable imaging and data acquisition is required.
The Portascan+ is unique with a large real-time screen, a patient database and the ability to combine ultrasound scans with uroflow data wirelessly by Bluetooth®.
Simple point-and-freeze operation makes the Portascan+ the scanner of choice for the busy clinical environment. The Portascan+ calculates the bladder volume automatically from an ultrasound image. An in-built thermal printer provides a permanent hard copy printout of results for accurate record keeping and archiving.
FORUMSView All (3)
0Replies3 years ago | Anyone with working unit OR service tools? Does anyone have an access to a working MediWatch / GE Portascan+ (PA-00253)? Card with the firmware in my unit died and there are two ways to revive it:
Does anyone have an access to either? I have the service manul but it doesn't hint for any portal with resources. Reply |
0Replies6 years ago | potascan how do i calibrate it it is asking for calibration on the screen thanks NicolleReply |
0Replies7 years ago | Code on machine What does E07 mean on the machine? Reply |
- Real-time ultrasound scanning & image capture
- Simple, intuitive software with touch-screen input
- 3.5 - 5.0 MHz abdominal probe for adults & children
- Automatic bladder volume calculation
- Touch-screen length & width callipers for kidney or other organ measurement
- Large database for storage of images, records and reports
- In-built thermal printer for immediate results
- Bluetooth® wireless connectivity (with PortaflowTM or BioscanTM PSAwatchTM reader)
- On-board touch-screen virtual keyboard for data input
- Optional USB input / output
- Integrated carry handle & protective screen cover
Dimensions: 36 cm (W) x 25 (H) cm x 9 cm (D)
Weight: 3.0 Kgs with battery & probe
Accuracy: 0-699ml +/- 10% +/- 20ml, 700-1500 ml +/- 7.5% +/- 25 ml
Organ Volume: 0-1500 ml
Battery Life: 3 hours
