Philips - IntelliVue MP80
Vital Signs/Multi-Parameter
The IntelliVue MP80* is designed to meet unique needs of the highest acuity care environments. You can also locally print in a harmonized layout. Weve redesigned the user interface to improve visibility of patient data, make it easier to use, and to enhance compatibility with standard software
0Replies8 years ago | How To Locate software and options on a Philips MP Series IntelliVue Monitor Reply |
VIDEOS
- Networked advanced care
- Dynamic Wave area features waves that automatically adjust in size depending on the number of waves configured.
- Capture, review, and store diagnostic 12-lead ECGs at the monitor before sending them to the IntelliVue Information Center. You can also locally print in a harmonized layout.
- Each NBP measurement now generates a column in the vital signs trend table. Measurements for other values are added to provide a comprehensive vital signs data set for the NBP measurement time, offering a more complete picture.
- The Smart Alarm Delay algorithm helps reduce the number of pulse oximetry nuisance alarms, allowing you to focus your attention where needed.
- Customized viewing options let you see and analyze data in graphical or numerical formats, and organize every on-screen element from waveforms to data labels as desired.
- Choice of display including medical-grade XGA and SXGA stand-alone, off-the-shelf models or Philips 38cm (15?)/43cm (17?) color LCD XGA display with touchscreen operation.
- Touchscreen navigation is available with compatible displays. Many functions are accessible through simple one-touch commands.
- High performance CPU
- Individual clinical measurement modules expand Philips clinical measurement offering. IntelliVue MP80 works with one Flexible Module Server plus the Multi-Measurement Server and extensions to increase measurement capabilities to match patient acuity.
- Remote SpeedPoint for easy data entry and navigation. Can be used together with a remote alarm device for visible and audible alerts.
- Portal technology: Compatible
- Waveforms: 4, 6, 8 (13 for ECG)
- Monitor screen display: One independent display -One slave display
- Screen navigation: -Touchscreen• Mouse -PS/2-compatible user’s choice -Remote SpeedPoint
- Multi-Measurement Server (MMS): Compatible Flexible Module Server (8 measurement slots)
- One supported Flexible Module Server
- Networking capability: Standard
