Philips - SureSigns VS2+
A new outlook on vital signs — the SureSigns VS2+Seeing is believing when it comes to the new SureSigns VS2+ monitor. With features designed to make taking vital signs easy, the VS2+ gives your staff the flexibility and freedom they need to take better care of their patients. From the easy-to-read viewing area,oversized buttons to the all-new pleth waveform display and intuitive navigation, the VS2+ provides the information you need, when you need it, maximizing the time spent at the bedside.
[list] [*] Oral temperature in just four seconds. [*] Bright, color backlit 4.3" LED screen. [*] 1 or 2D bar-code scanner programmable for multiple ID fields. [*] NBP modes, including auto intervals, user-defined interval program, and manual start/stop. [*] Time-sync network clock. [*] Oversized, one-touch NBP on/off button. [*] Pleth waveform display. [*] Confirmation of export records easily seen in green. [*] Stores up to 100 patient records. [*] Uses the same supplies as all Philips monitors. [/list]
Height | 7.5 in |
Length | 5.7 in |
Weight | 4.3 lbs (including pTemp plus probe and covers, recorder plus paper, and battery) |
Width | 7.1 in |
