Siemens - Luminos Agile
A RADical new way in fluoroscopyLuminos Agile is the first patient-side system with dynamic flat detector technology, height-adjustable table and true dual use fluoroscopy & radiography capability. This system is so agile, you can achieve imaging excellence, simplify your workflow and expand your patient base.
4Replies2 years ago | Error code 2202/243 we have error 2202/243 on Illuminos Agile. can you please let me know that mean?Reply |
The first patient-side system with true dual-use capability for fluoroscopy and radiography [list] [*] Improve the patient’s experience, customer satisfaction, and your competitive advantage [*] Cater to a broader spectrum of patients more successfully [*] Optimal radiography with the Ysio option increases utilization rates [/list] The first patient-side system with a flat detector for fluoroscopy and radiography [list] [*] High-quality dynamic and static imaging with the 43x43 cm (17“x17“) flat detector [*] Comprehensive dose reduction with CARE [*] Unlimited imaging flexibility with the Ysio option [/list] The first patient-side system with a height-adjustable table for fluoroscopy and radiography [list] [*] Adjustable table from 65 to 112 cm (25-44“) height for easy patient transfer [*] Effortless system movement with the fully motorized tower [*] Open design and high weight capacity up to 275 kg (606 lbs) to cater to all patients more easily [/list]
