Drive Medical - Semi-Electric (Single Crank)
by Drive Medical
Drive Medical's Semi-Electric Bed (Single Crank)
[list]      [*] Quiet, smooth operation.      [*] Side clips under angle iron store shaft when bed is unassembled.      [*] Easy to set up.      [*] Bed ships in two cartons.      [*] Head and foot section adjust electronically. Height adjusts manually.      [*] Back and foot adjustment allow for an anatomically correct sleep surface.      [*] Channel frame construction provides superior strength and reduced weight.      [*] Zinc coated spring deck.      [*] Pendant has clip that allows it to be mounted over bed rail.      [*] Pendant will operate hand and foot section at the same time.      [*] Reinforced frame resists twisting and bending.      [*] Heavy duty, bed ends are attractive in any décor and easy to maintain.      [*] Head and foot ends are interchangeable with Invacare® and Sunrise®    [/list]
Height24.5 in (max)
Bed TypeElectric
Length 88 in
Weight185 lbs
Patient Weight Capacity450 lbs
Width36 in
