Olympus - CF-Q160L
by Olympus
Video Colonoscope
[list]    [*] Superior image quality with large display size provides enhanced details throughout the image plane.    [*] When used in combination with the Olympus dedicated flushing pump and CV-160 video system center, a continuously clear view is ensured by an auxiliary water function that removes mucus and stool inside the colon at the touch of a switch on the scope.    [*] Extra-wide 140° field of view and extensive 4-way angulation (180° up/down and 160° right/left). 3.7 mm diameter channel can handle a wide range of treatment requirements and provides high suction capability even when forceps are being used.    [*] Ergonomically designed grip enhances scope maneuverability while redesigned easy-to-access knobs and user-selectable switches improve operability.    [*] Fully compatible with the CV-160/140.    [*] Scope ID function stores individual scope information and displays it on the monitor to facilitate endoscopy suite management.    [/list]
Diameter: 12.8MM  Channel: 3.7MM  Working Length: 168CM  Field of View: 140°
