Olympus - CF-Q160AL
by Olympus
Innoflex video colonoscope
The CF-Q160AL provides an innovative insertion tube design which makes performing a colonoscopy easier. With the variable stiffness insertion tube, the user can adjust the flexibility of the insertion tube to easily adapt to the internal contours of the colon for precise insertion.
[list]    [*] The flexibility of the variable stiffness insertion tube can be adjusted to suit the internal conditions and contours of the colon, simply by turning a knob below the control section.    [*] Superior operability and insertion capability make these all-purpose scopes ideal for routine procedures.    [*] Large display size delivers superior image quality with a sharper, crisper image and life-like color from edge to edge.    [*] When used in combination with our OFP dedicated flushing pump and CV-160 video system center, a clear view is ensured by an auxiliary water jet that removes debris inside the colon at the touch of a switch on the scope.    [*] Extra-wide 140º field of view and extensive 4-way angulation (180º up/down and 160º left/right) enable complete and comprehensive examination of the colon.    [*] 12.8mm outer diameter insertion tube.    [*] 3.7mm diameter channel ensures sufficient suction capability even when an EndoTherapy accessory is in place.    [*] Ergonomically designed grip enhances scope maneuverability while redesigned easy-to-access knobs and user-selectable switches improve operability.    [*] Fully compatible with the CV-160/140.    [*] Scope ID function stores individual scope information and displays it on the monitor to facilitate endoscopy suite management.    [/list]
