GE HealthCare - Optima XR220amx
by GE HealthCare
Compared to its predecessors, the Optima XR220amx is smaller for easy maneuverability. More powerful for quality imaging. Fully integrated for reliable digital workflow. With more storage. And better ergonomics. It's powered by FlashPad, GE's wireless digital detector featuring a square shape and two handles for easy positioning. And dedicated Ultra-Wideband wireless technology helps enable independent, secure, reliable communications.
0RepliesFri Jun 06 2025 | Batterirs The old batteries just like the new batteries I installed will not charge and drop down to zero. I already replaced the firefly board batteries still will not charge. Equipment: GE optima 220 Reply |
0RepliesSat Oct 19 2024 | service manual Looking for a service for a i optima xr220amx&240amxEquipment: GE optima XR220amx and XR240amx Reply |
2RepliesThu Mar 21 2024 | No Power I have unit that will not power on. It is used, worked when we purchased it (10~ days ago), was able to take an image and shows that it is charging/charged. But now the power button will illuminate blue when needed, but as soon as breaks/buttons/arm piece are moved, it shuts down. The breaker does not trip, the power just seems to turn off. Suggestions? Thank you. Reply |
[list] Designed for Digital, Designed for You [*] The simple, large touch screen monitor allows for fast exam set-up, easy image review & manipulation, and a simple wireless push to PACs. [*] The wireless FlashPad detector frees you to position more easily and correctly. [*] The integrated design has all components working together, helping maximize the efficiency of the system and you. A system that works as hard as you do [*] Gain the productivity, image quality and functionality of a RAD room in a mobile environment. [*] An integrated digital system with improved battery management designed for efficiency, 24/7 availability, and minimal boot-up time. [*] Choose the power you need with 15kW and 30kW generator options. [/list]
