GE HealthCare - Brivo XR285amx
by GE HealthCare
The Brivo XR285amx is the next generation of GE’s familiar AMX analog system.
The Brivo XR285amx is a reliable solution to mobile X-ray, through an easy to use system, touch-screen user interface and the capability for continuous use in a busy hospital environment.  [list]  [*] The long battery life, shortened charge cycle time and the ability to charge while exposing enables your technologists to cover multiple floors and departments.  [*] Time-tested AMX technology in an upgraded design allows for easy maneuvering, user-friendly ergonomics and images you’ve come to expect from your GE mobile.  [*] A smaller footprint and a more powerful generator will increase performance, helping to provide your technologists with the confidence and tools they need to do their work.  [/list]
FORUMSView All (4)
-Charley R
Fri Feb 03 2023
Errors
What are the steps for the following errors? I have a service manual, but nothing about errors. 8308039 8400006
Equipment: GE Healthcare - Brivo XR285amx
-VAPO
Tue Aug 21 2018
Support Manual
Hello, I'm looking for the support manual for the amx285, S/N: 1029200WKI Waiting for your kind response. Regards.Reply
3
-znelson
Mon Oct 27 2014
GE Brivo XR285amx
Unit shut down at the termination of a 120/40mAs exposure.
With the AC cord plugged in: power button pressed, 2 series of relays clicking, battery indicator lights up showing full charge, lock/unlock button and numbers light up, AC cord unplugged and unit shuts down after 15 sec.
With AC unplugged: power buttonpressed, 2 series of relays clicking, battery indicator lights up showing full charge, lock/unlock button and numbers light up, passcode entered and was able to move the unit for approximately 1” and unit shuts down.
The Brivo XR285amx is a self-contained battery operated mobile X-Ray imaging system designed for performing radiographic exams at the point of care when it is not safe or practical to move the patient to the radiographic room.    Brivo XR285amx is suited for routine radiographic procedures within a hospital including radiology departments, intensive care units, cardiac care units, emergency departments, operating rooms, orthopedics, pediatrics, hospital rooms and clinics.    Key technology features include:  [list]  [*] Designed to be used with conventional film or CR cassettes.  [*] Designed for 24/7 availability. Use with battery or make exposures while the unit is charging.  [*] Automatic charging algorithms allow the system to be re-charged even if batteries are not fully drained.  [*] Average system charge time of 3 hours.  [*] Choose your generator power with 15kW (nominal) generator or the 30kW (nominal) option.  [*] System can be driven within 4 seconds of activation.  [/list]
