Olympus - BF-160
by Olympus
With the EVIS EXERA BF-160’s slim 5.3mm diameter distal end, 2.0mm diameter channel and newly-developed high-resolution color-chip CCD built into the scope tip, it is now easier to obtain the precise manipulation and detailed imaging you need for examination of the tracheobronchial tree. Equally well-suited for routine endoscopic applications, this versatile scope is fully-compatible with the Olympus CV-160 video system center as well as the CV-100/140 video system centers, offering you a cost-effective solution to all your endoscopic requirements.
[list] [*] Incorporates a compact, color-chip CCD (built into the scope tip) to provide clearer and more-detailed images than previous Olympus models [*] Larger image display size for easier viewing without sacrificing image quality [*] Narrow 5.3mm diameter distal [*] Length of the insertion tube has been increased from 550mm to 600mm to improve insertion and maneuverability of the scope [*] Bending section angulation range of 180º UP/130º DOWN allows easier handling and maneuverability in the smaller distal airways [*] Fully insulated to provide compatibility with electrosurgery and lasers [*] Ergonomically designed control section and switch layout helps reduce operator fatigue [*] Standard accessories are the same as those for all Olympus bronchoscopes [/list]
