Olympus - BF-P160
Featuring a small color-chip CCD incorporated in a videoscope.The EVIS EXERA BF-P160's extra-narrow insertion tube measures a mere 4.9mm in diameter offering dramatically improved insertion capability. The new CCD technology delivers superior high-resolution images, excellent color reproduction and a large display size for more accurate observation. The 2.0mm diameter channel provides excellent suction performance and allows insertion of a wide variety of Endo-Therapy instruments during procedures. The BF-P160 is compatible with the new Olympus CV-160 video system center.
[list] [*] Incorporates a compact, color-chip CCD (built into the scope tip) to provide high-resolution images [*] CCD technology provides larger image size than previous models, allowing for more accurate observation [*] Narrow 4.9mm insertion tube outer diameter for improved insertion capability [*] The BF-P160 is interchangeable with an EVIS EXERA Gastrointestinal endoscope because the CV-160 Video System Center is designed to accomodate either type of scope [*] Bending section angulation range of 180º UP/130º DOWN allows easier handling and maneuverability in the smaller distal airways [*] Fully insulated to provide compatibility with electrosurgery and lasers [*] Ergonomically designed control section and switch layout helps reduce operator fatigue [*] Standard accessories are the same as those for all Olympus bronchoscopes [/list]
