Olympus - BF-1T160
by Olympus
Designed to take bronchoscopic treatment to the next level
The new Olympus EVIS EXERA BF-1T160 scope incorporates a wide 2.8mm channel in a slim insertion tube that measures 6.0mm in diameter. Besides giving you more treatment options than ever before, this powerful scope also delivers larger, high-quality images thanks to the newly-developed high-resolution color-chip CCD built into the scope tip at the distal end.        The BF-1T160 is fully-compatible with the Olympus CV-160 video system center and its existing CV-100/140 video system centers, offering you a cost-effective solution to all your endoscopic requirements.
-martin1
11 years ago
consult
Hi, how get a complete repair article? Thanks
[list]    [*] Incorporates a compact, color-chip CCD (built into the scope tip) to provide clearer and more-detailed images than previous Olympus models    [*] Expanded image size makes it easier to observe the minute details and subtle textures critical to successful procedures    [*] Its 2.8mm diameter channel increases suction capability and allows a greater variety of Endo-Therapy accessories to be used, including a balloon-equipped ultrasonic probe    [*] Bending section angulation range of 180º UP/130º DOWN allows easier handling and maneuverability in the smaller distal airways    [*] Fully insulated to provide compatibility with electrosurgery and lasers    [*] Ergonomically designed control section and switch layout helps reduce operator fatigue    [*] Standard accessories are the same as those for all Olympus bronchoscopes     [/list]
