Olympus - BF-XP40
by Olympus
Designed specifically to enable direct inspection of the peripheral bronchi.
Suitable for pediatric applications as well. Its insertion tube and distal end measure a mere 2.8mm across. As a result, insertion into the peripheral bronchi can be accomplished with greater ease. And since this sophisticated scope offers high-resolution and brightness, you won't have to settle for reduced visibility. It also provides improved operability, increased BAL efficiency and an enhanced ability to clean via a number of easy-to-use features and a comfortable, ergonomic design.
[list]        [*] Slim 2.8mm diameter        [*] Tip bending range of 180° UP and 130° DOWN        [*] Suction and biopsy valves allow BAL testing to be performed more efficiently        [*] 1.2mm diameter instrument channel is compatible with the following Olympus accessories: FB-44D-1 and FB-56D-1 biopsy forceps, BC-201C cytology brush        [*] New ergonomic design results in increased comfort when using the BF-XP40         [/list]
