GE HealthCare - AS/3
by GE HealthCare
A lightweight and fully featured monitor
The Datex AS/3 Multi-Parameter Patient Monitor is a light weight and fully featured monitor with three lead ECG, Temp, Sp02, and niBP capabilities.
FORUMSView All (23)
-BIOMEDICA SAN BENITO
Thu May 30 2024
NIBP MODULE PROBLEM- AIR LEAKAGE
Hello!
I have an issue with my NIBP module from the Datex Ohmeda AS/3. My pump wont go higher than 210 mmHg, which results in the air leakage error in the monitor. I have already replaced all the valves, I checked for leakage on all the tubes, and also even changed the pump with another module I have, but the error still remains. What else could be causing this problem? Thank you!
-Peachtreesleeper
Fri Sep 15 2023
Can I use a datex ohmeda as/5 screen on an as/3. Any solutions to which monitor screens would work with my As/3 modules? Thanks
Can I use a datex ohmeda as/5 screen on an as/3. Any solutions to which monitor screens would work with my As/3 modules? My monitor died and need a new monitor or refurbished monitor that works with the modules.
-dej
Fri Dec 28 2018
Datex Multiparameter module - NIBP leaking question plus need silicone tubing size
Hello and thanks for reading. We have a Datex / Ohmeda AS/3 with multiparameter module. The NIBP 'works' but I'm suspecting a leak somewhere in the system as it seems have to 'hunt' for the correct pressure when doing a reading and the observed mmHg on the screen descends too quickly when reading NIBP. Many times it just reports a leak. We have ruled out the tubing and cuff (replaced plus they work just fine on another monitor). Internal inspection of the multifunction module that slides into the AS/3 reveals no obvious defect. I poked around on the silicone tubing that goes from the connector to the pump / transducer and removed it and it seemed a bit loose. In addition I slightly tore one end of the tubing. It's precisely fitted, so cutting off the torn 5mm yields a tube that is too short to fit back in place. This tubing is 3.5mm ID and 7mm OD. Can't find anything that exactly fits this tubing size but I'm about to order a few that are close. So, two question: 1) Do you have a description for this exact tubing? 2) What other parts may I look at in the NIPB that might 'leak' (pump, transducer, solenoid)? I can get a working module for $200 but I hate to trash this one. Thanks. dejswa@yahoo.comReply
  • ECG, Sp02, Temp., NIBP. And BP patient monitor
  • 2 hour battery life with swappable battery bays
  • 12.4 x 16.1 x 5.3 inches, small and compact
  • 14” color video CRT display
  • Anesthesia alarm system classified into three categories
