Datex Ohmeda - 3740
by Datex Ohmeda
Pulse Oximeter
The Ohmeda 3740 is a stand alone, non invasive, arterial oxygen saturation monitor with continuous, real-time SPO2 and pulse rate readings. Trend information is available through both the analog and digital output ports. This monitor has both visual and audible alarms and a battery backup.
-mMiller
9 years ago
Omeda 3740
Need a operators manual for omeda 3740 pulse ox machine
-GaryBiomed
11 years ago
Not keeping memory
Have a couple 3700s & 3740s that are not holding the overnight trending memory.
batteries are good, not sure if it's a bad IC?
SERVICE COMPANIESView All Pulse Oximeter Companies
  • Immediate, continuous oxygen saturation information.
  • Portable, lightweight, versatile and easy to use.
  • Ideal for a wide range of applications intensive care, pulmonary rehabilitation, ventilator weaning, anesthesia and post anesthesia care, sleep studies, in-hospital transport, emergency care and oral or plastic surgery.
Pulse Rate Range40-235 BPM
Weight5.5 lbs
Memory8 hr data storage for SpO2 and pulse rate
Operating Life3.5 hr
SpO2 Range0-100%
  • Chemistry - Sealed Lead Acid
  • Nominal Voltage 12v
  • Nominal Capacity 2.3Ah
  • Terminals .187" faston
  • Dimension 7.01x1.34x2.52
  • Weight (pounds) 2.07
