SIGMA - 6000+
by SIGMA
IV Pump
The Sigma 6000 Programmable Volumetric Infusion Pump is designed to provide accurate and reliable administration of all intravenous drugs and fluids. The program feature allows you to preset up to 12 different rate and volume limit combinations for the gradual increase or reduction of intravenous fluids and medications. Piggyback (or secondary) medication may also be automatically infused at a delivery rate and volume independent of the primary infusion, with automatic changeover to the primary infusion when the piggyback infusion is complete.        The infusion rate is selectable from 0.1 ml/hr to 999 ml/hr. And, since the 6000 Programmable Pump utilizes standard low cost (Abbott, Baxter Travenol or Kendall McGaw) micro and macro drip administration sets, it offers a high degree of versatility in tubing selection and operation.        To ensure safety and ease of operation, the 6000 has a user prompting system and a full range of diagnostic alarms. Fluid flow protection is provided through an automatic safety clamp.
FORUMSView All (9)
-mag91
10 years ago
bad ram
bad ram
-carmagar4
11 years ago
Sigma 6000+ service manual
I need to read a Service manual, can anyone help me to obtain it in PDF format?
-carmagar4
11 years ago
Bad Ram
I owe 3 of these pumps and all sudenly starts to give me a code BAD RAM and I'm unable to use them anymore, how to fix it?
Height7.5 in
Length 7.5 in
KVO Rate1 ml/h <1 ml/hr = infusion rate
Weight10.2 lbs
Flow Accuracy5 %
Width3.5 in
