Abbott - Plum XL
The Plum XL Micro/Macro is a dual-line volumetric infusion system designed to meet the growing demand for hospital-wide, as well as alternate site and home healthcare, standardization. With its primary line, secondary line, and piggyback fluid delivery capability, the Plum XL is suited for a wide range of medical/surgical and critical care applications. Full compatibility with LifeCare¨ PlumSets¨ administration sets and accessories, and the LifeShield¨ needleless protection systems, makes the Plum XL a convenient and cost-effective infusion system.
FORUMSView All (10)
0Replies9 years ago | plum XL manuals Andy one have address I cant find them on line? Reply |
2Replies9 years ago | Air In Line Errors Fixed Without New Parts!!! Hello Everyone, I generally don't spend much time troubleshooting any of the sensor errors that these pumps seem to have as the mechanism assemblies have dropped significantly in price. Recently I decided to work through an "air in line" error message that kept re-appearing to see if I could increase my understanding of exactly how these sensors worked. The error code that I was receiving was 8-1 "Greater than 500uL of air detected entering the cassette withing the last two intake strokes". After verifying that the cassette was fully primed and working on other pumps I pulled the mech out for a closer look. I read the theory of operation portion of the service manual on the Bubble sensor PWA and it led me to the set of potentiometers on the board itself. R21 and R12 can be adjusted to move the centerpoint frequency of the Phase Lock Loop portion of the receiver circuitry. I belive that R12 is for the Proximal Air Sensor and R21 is for the distal air sensor. I measured these 2kohm pot's to be 683 ohms and 522 ohms respectively. After adjusting the prox air pot to 522 ohms to match the dist air pot; and re-assembling the pump I no longer had an air in line error. I did test the pump to ensure that it alarmed with even a small amount of air in the line and it functioned correctly! Please be aware of adjusting the pots too far to the point that the sensor does not function, this can be lethal for the patient so please ensure proper functions after making your adjustments. Enjoy the money that you will save your companies by performing this little procedure instead of swapping out your mech's. Thanks, Reply |
0Replies9 years ago | I-95 Our plum micro macro xl is giving a "I-95" error. how do we fix this? Reply |
- The pump runs from 1mL/hr up to 999mL/hr, and runs a 1mL/hr KVO at dose end
- The Abbott Plum XL IV pump is capable of running parenteral (blood) and non-parenteral (enteral) fluids, and may use standard fullfill, partfill, syringe, and vial containers
- Volume infused accumulation displays for primary and secondary solutions
- Battery operation (full charge lasts for 8 hours at 25 ml/ hr)
- Self test
- Simple setup (one hand cassette loading0
- Automatic memory retention of all previous therapy settings and fluid delivery data until cleared by user
Height | 8.25 in including pole clamp |
Length | 8.75 in including pole clamp |
Flow Rate Range | 1 to 999 ml/h |
KVO Rate | 1 ml/h |
Weight | 7.78 lbs with battery |
Flow Accuracy | 5 % |
Infusion Pump Type | General-Purpose |
Width | 7.5 in including pole clamp |
Power Requirements: 100-130 VAC
