Smiths Medical - CADD-Legacy Plus 6500
by Smiths Medical
The CADD-Legacy® PLUS pump is for continuous and intermittent therapies… because performance runs in the family. Includes pump, single-use 50-/100-ml pump pouch, 2 AA alkaline batteries, non-sterile demo cassette, operator's manual, patient guide and carrying case.
1ReplyFri Aug 04 2023 | Biomed Functions Code What is the biomed functions code? Reply |
5RepliesMon Dec 19 2022 | Error code 1856 Hi what’s does error 1856 means ?Reply |
1ReplySat Sep 12 2015 | CADD legacy pump 6500 error code 1830 What's the meaning of errror code 1830 en how can I remove it from the pump. Or is it neccessary to go to the service center? Reply |
[list] [*] Easy to Read Display - Easy to read and understand display screen provides information for programming adjustments and troubleshooting [*] Cassette Detection - Cassette detection sensor is designed to detect cassette attachment [*] Occlusion Detection - Upstream and downstream occlusion sensors are designed to alert the patient and clinician if interruption of fluid delivery occurs [*] Air-in-Line Detection - Air-in-line detector with Off, High- and Low-sensitivity settings is designed to alert the patient and clinician if air is present in the administration set tubing [*] ON/OFF Key - ON/OFF key allows pump to be placed in low-power state and is designed to save battery life [*] Event Memory - The last 1,000 events in the pump's history can be downloaded either directly or remotely (using a modem) to a PC using the CADD-DIPLOMAT® PC Communications System [*] Reliability - CADD® pump reliability and durability can mean less down time and fewer interruptions to therapy [/list]
| Height | 4.4 in |
| Length | 1.6 in |
| Flow Accuracy | 6 % nominal |
| Infusion Pump Type | Ambulatory |
| KVO Range | 0 to 125 ml/h |
| Width | 3.8 in |
