GE HealthCare - LightSpeed 16
by GE HealthCare
The Power to Scan. Finer. Faster. Further
With sub-millimeter slices and routine 16-slice coverage, GE LightSpeed 16 delivers a whole new world of clinical value - all while addressing your productivity and care of the patient.
FORUMSView All (16)
-Jonatan Marroquin
Wed Feb 07 2024
MX200 certificate
Hello
I need to send an MX200 tube to the United States
But the customs of my country requests the MSDS certificate to be able to send it.
Can you support me with a certificate even if it is for another tube model.
Thank you in advance for your response
Equipment: GE HealthCare - LightSpeed 16
-LoriLou
Thu Dec 15 2022
Dosage Report for GE Lightspeed 16
I am looking for instructions on how to run the dosage report from the scanner. I have a 16 slice and am not even sure we have the correct software version. But I'm trying to bring our record keeping systems into the 21st century anyway!Reply
-Redbootz
Tue Jan 26 2021
Repeat scans
Using a GE Lightspeed scanner. If you need to repeat an exam for example a patient moved would this be set up as a new scan series under a new patient ID? Would each repeat have its own dose report? Or would it be logged as the same series and dose report? Would all of it be saved for total radiation in one or individually? Thank you Reply
[list]    [*] The 4th evolution in LightSpeed    [*] GE microVoxel technology    [*] Image quality in three dimensions    [*] Scan Finer, Further, Faster        [/list]
Type (configuration)Multislice
Slices16
Gantry (Max. Clearance) 70 cm
