GE HealthCare - HiSpeed NX/i
by GE HealthCare
The HiSpeed NX/I Dual CT scanner by GE has set the standards higher for scanning speed, resolution and even coverage. This CT scanner provides you with flexibility, advanced clinical applications and most of all, exceptional patient care. It has been designed with new technologies that will give you high image quality for the lowest dose. When you purchase this CT scanner, you will not only receive excellent diagnostic information, you will also see an increase in your productivity as well. The HiSpeed NX/I Dual CT scanner is equipped with the multislice technology. This technology provides the scanner with features such as Real time beamtracking, HiLight detector, AutomA, Optimum helical pitchs and Bowtie filter. The gantry and table allows for a 120cm scan range. It is equipped with positioning lights and breathing lights. The minimum required space for this scanner is 13 m2. This scanner will allow you to acquire two thin slices simultaneously in the same amount of time it would take for a single slice scanner.
0RepliesThu Jan 12 2023 | Documentation Hi All, I'm looking for user manual and CE certificate for this system (no Pro version). Someone have that old stuff?Reply |
2RepliesMon Sep 06 2021 | Scout Inverted colors Hi everyone, we have a CT that all of the sudden has started to reverse the brightness of the image, but only for scout and only during group positioning. The result is that air looks bright white and bones dark black, and it's really annoying. Has anyone encountered a similar problem in the past? EDIT: did a complete LFC and the problem still persist. Reply |
0RepliesWed Oct 21 2015 | Welcome to NXI_MDS HiSpeed Series Login Password Hello CT experts, I have a problem with my NXI CT dual. After booting it says system is now ready but then goes into the login window as asking for password. I tried everything: root, root / root operator/ genesis, genesis/ genesis, 4$apps but no luck. Who can help me please Reply |
[list] [*] Offers real time imaging processing [*] Fast scans and reconstruction times [*] Equipped with a operator console that allows for multitasking [*] Advanced clinical applications options available [*] AutoFilming, AutoArchive, AutoVoice and AutoTransfe [/list]
| Type (configuration) | Multislice |
| Slices | Dual |
