GE HealthCare - 5250 RGM
by GE HealthCare
Anesthesia Gas Monitor.
The technical class for the 5250 RGM is designed to give participants the information necessary to identify all components of the pneumatic and electrical systems including their major functions, and repair/replacement procedures. Hands-on exercises are designed to reinforce skills required to maintain, adjust and calibrate the monitor, including performing a complete tubing kit replacement.       [list]       [*] Utilizes new electroluminescent display and infrared touchscreen control technology.       [*] One compact panel integrates data display, control, alarm, and message management system.       [*] Display panel lifts off the monitor for convenience.       [/list]
FORUMSView All (20)
-Stevan
Fri Mar 04 2022
CO2 and calibration
How often does it have to be calibrated? I need it only to measure CO2 in patients, rather than anything else.Reply
-Gary Takowsky MD
Thu Aug 13 2020
Gary Takowsky MD
How can you take the front cover off?Reply
-Leeaumd
Thu Jan 30 2020
How can you unblock sample filter?
How can you unblock sample filter?Reply
SERVICE COMPANIESView All Medical Gas Monitor Companies
Key Features
  • Cost-effective standalone monitor capable of measuring any one of five anesthetic agents:
  • Halothane
  • Isoflurane
  • Enflurane
  • Desflurane
  • Sevoflurane
  • Provides comprehensive intraoperative respiratory and anesthetic monitoring
Monitored Parameters
  • Inspired and expired O‚, CO‚, and N‚O concentrations
  • Minute volume and tidal volume
  • Peak, minimum, and mean airway pressures
  • SpO‚ (pulse oximetry) and pulse rate
  • Circuit oxygen (O‚) concentration
Physical Characteristics
Main Chassis
  • Dimensions: 12.4 × 7.5 × 16 in. (32 × 19 × 41 cm)
  • Weight: 22 lb (10 kg)
Display
  • Dimensions: 11.4 × 7 × 3 in. (29 × 18 × 8 cm)
  • Weight: 3.5 lb (1.5 kg)
