This black and white, in-clinic system employs convex and linear probe technology.Ask a New Question1Reply-kassachew Mon Jan 03 2022 | Mon Jan 03 2022support I need aloka ssd 1400 service manual?
thanksReply |
1Reply-Svetaslav Wed Apr 22 2020 | Wed Apr 22 2020BUS ERROR
After a long downtime, we decided to use the aloka ssd-1400 scanner. When turned on, the BUS ERROR error comes out almost immediately, tell me where to dig, maybe the battery is dead, or is there another problem? Also looking for service manual, please
Reply |
0Replies-Svetaslav Wed Apr 22 2020 | Wed Apr 22 2020BUS ERROR After a long downtime, we decided to use the aloka ssd-1400 scanner. When turned on, the BUS ERROR error comes out almost immediately, tell me where to dig, maybe the battery is dead, or is there another problem?Reply |
- Multi-frequency system Allows the clinician to scan a wide range of different size patients with the same probe.
- Preset function Use the 15 user-programmable presets to register preferences and recall them with a simple of touch of a button.
- Multi-Stage Dynamic Focusing: the transmitted ultrasound beams are focused throughout the entire field of view. In addition, up to 4 user selectable focal zones can be selected to optimize resolution in the area of interest.
- Image processing Select (IPS): enables users to pre-program up to 8 combinations of imaging factors for each of 15 pre-sets
- Image select function: Transmit, frequency, receive frequency, and transducer aperture size are changed to optimize the image. R=resolution; S=standard; P=penetration
- Automatic B-gain control (ABC): provides hands free automatic system gain control providing a constant image brightness.
| Cart Based | 1 |
| Clinical Applications | Colorectal |
| Portable | 0 |
| Doppler Modes | Pulsed Wave (PW) Doppler HPRF PW Doppler Continuous Wave (CW) Doppler |
| Image Display | 12 in diagonal viewing monitor |
| Imaging Mode | B, B/B, B/M, M |
B-mode: Frame correlation, contrast, AGC, relief
M-mode: Contrast, AGC, relief, FTC
D -mode: Contrast, reject, P-CMP, smooth, reso
256 grayscale levels
