CritiCare - 507 EL
by CritiCare
Scholar III Patient Monitor
Compact, lightweight and portable. A cost-effective solution for bringing ECG, pulse oximetry, noninvasive blood pressure, temperature, and respiration to hospitals, clinics, and private offices. The Scholar ® III combines all essential standard-of-care parameters for vital signs monitoring and conscious sedation procedures in one compact system. Continuously monitor five critical parameters (ECG, DOX™ digital pulse oximetry, ComfortCuff™ NIBP, temperature, and respiration) on a broad range of patients, from neonate to adult. The high resolution color TFT screen optimizes viewing of three patient waveforms while presenting digital values on large color-coded LED’s.
FORUMSView All (7)
-Sonichouse
9 years ago
Wire disconnect in unit
Though I have been looking at the schematics for this unit, I have a green wire with inline fuse 1 end connected to the 4 pin power junction on main pcb, but can't determine where the other end connects. I pretty sure it is the sense wire for the battery charging circuit, which probably should be connected to the Ac/ charger jack on back panel, but not sure which pin. Anyone have a suggestion?
-Medtechman
9 years ago
Need Service Manual, Schematics
Display functions but unit does not. Need to trace for circuit board and component damage
-Twila
10 years ago
need thermal paper
need thermal paper for machine.
[list]    [*] Three-lead ECG    [*] Digital SpO2    [*] NIBP with ComfortCuff technology    [*] Heart rate    [*] Temperature    [/list]
Height7.6 in
Length 10.7 in
Weight8.5 lbs
PrinterThermal line printer
Temperature Range15 to 40 °C
Width10.1 in
ECG:  Number of Leads: 3  Lead View: I, II, III  Gain Selection: x1/2, x1, x2, and x4  Frequency Response: Diagnostic: 0.05 to 100 Hz  Monitor: 0.5 to 40 Hz  Electrosurgery Protection: Yes  Defibrillation Protection: Yes  Pacer Detection/Rejection: Yes    Non-invasive Blood Pressure:  Technique: Oscillometric upon inflation  Auto. Measurement Cycles: 1, 2, 3, 5, 10, 15, 30, 60 min.; 2, 4 hr  Adult Range: 30-250mmHg  Neonate Range: 30-140mmHg  Resolution: 1mmHg  Transducer Accuracy: ±2mmHg or ±2% of reading, whichever is  greater, over full range  STAT Mode: 5 minutes of consecutive readings    Pulse Oximetry:  Range: 1 to 99%  Resolution: 1%  Accuracy: ±2% (70 to 99%)  Method: Dual wavelength LED  Averaging Time: Selectable 3 to 21 seconds  Search Time: Selectable, 10 to 40 seconds  Sensor Type: Reusable and Disposable selections  Audio: Beep with each detected pulse, pitch  varies with oxygen saturation    Heart (Pulse) Rate:  Source: ECG, SpO2, NIBP  Range: 30 to 300 bpm (NIBP 30-240 bpm)  Accuracy: ±1 bpm or ±1%    Temperature:  Channels: 1  Range, Accuracy: 20 to 45° C; 68 to 113° F (± 0.1° C)  Display Resolution: 0.1° C/F  Probe: YSI-400 Series    Respiration:  Range: 9 to 150 breaths/minute  Resolution: 1 breath/minute  Accuracy: ±1% or ±1 breath/min  Source: Impedance    Alarms:  Alarm Indication: Audible, Visual  Alarm Volume: User selectable: 1-10, Off  Alarm Silence: Yes, 2 minutes or permanent
