Burdick - Eclipse 850
The Eclipse 850 Electrocardiograph provides features and performance typically found on units costing much more.The Eclipse 850 Electrocardiograph provides features and performance typically found on units costing much more. A large preview display saves time and money by reducing retakes. Battery operation gives the unit enhanced mobility. Computerized interpretation, using the well-respected Glasgow interpretive program, provides a silent second opinion with documented accuracy. Additional options for internal storage, fax and communications, and exercise stress, allow you to configure a system that meets your needs for today and tomorrow.
FORUMSView All (15)
0Replies3 years ago | Saving EKG without printing Can I save an EKG on the Eclipse 850 if I am out of paperReply |
0Replies5 years ago | No Power- Burdick - Eclipse 850 There's no power when plugged in to AC, even after installing new battery and charging overnight. Reply |
0Replies6 years ago | Password I'm trying to change date, time, delete patients, actually I need to reset the unit to its factory defaults but we don't have the password. Is there a master password for these units?Reply |
- Automatic; manual or 12-lead rhythm operation for maximum flexibility
- Easy-to-read backlit preview screen allows patient monitoring
- Optional, powerful interpretation algorithm includes five factors as well as AccuPrint™ restricts ECG printout when leads are not attached correctly, ensuring a
- Interpretive models with communications are compatible with FAA regulations
EKG/ECG Type | Rest |
Weight | 9 lbs |
Dimensions: 11 x 13 x 3.25 inches
