Beckman Coulter - Allegra X-14 Series
by Beckman Coulter
This benchtop centrifuge is convenient, hardworking, reliable, and will speed up your process, cycle after cycle. Available in refrigerated and constant-controlled temperature models, the X-14 Series offers BioCertified features for security from contamination; ARIES Smart Balance Rotor System for faster setup and run times; and a versatile rotor for accommodating tubes, bottles, and microplates. The robust cooling system of our refrigerated model reduces wait time and shortens run cycles. [b]North America Only[/b]
0Replies8 years ago | Allegra X-14R motor Does anyone have the drive assy or motor part number? Thanks in advance, Randy Ozark Biomedical Reply |
0Replies11 years ago | Service Manual Would anyone be able to provide the service manual for this centrifuge or the calibration procedure? Our centrifuge is down and needs calibration. Any help would be greatly appreciated! Reply |
[list] [*] ARIES Smart Balance Rotor automatically corrects imbalance up to 50 grams [*] Versatile rotor accommodates tubes, bottles, and microplates [*] BioCertified* swinging-bucket and fixed-angle rotors [*] 3 mL and larger centrifugal devices [*] At maximum speed in your swinging bucket rotor Fast & Slow Blood Component Spins [*] Up to 3 liters [*] In just 14 minutes Skip Steps in Cell Culturing [*] Save time and labor [*] Eliminate 15 mL or 50 mL conical tubes [*] Reduce a potential contamination step Complete Your Run--Even with Imbalance [*] ARIESTM Smart Balance Rotor automatically corrects for imbalance [*] Up to 50 grams opposing loads [*] Eye balance your samples with confidence Enter Values Directly with User-Friendly Prompts [*] Avoid scrolling [*] Save time [*] Minimize training [/list]
Height | 13.5 in |
Length | 24.5 in |
Orientation | Benchtop |
Weight | 283 lbs |
Maximum Speed | 10200 rpm Fixed Angle Rotor |
Width | 30 in |
[list] Set Temperature: Preset to 20°C Acceleration: 10 Profiles Audible End-of-Run Tone: Yes Automatic Rotor Identification: Yes Deceleration: 11 Profiles Timed Run: to 99 hours, 59 min Ventilation Clearances Required: Sides and Rear: 7.6 cm (3.0 in) [/list]
