Draeger - Babylog 8000
Neonatal VentilatorMove up to a milestone in neonatal respiratory care with a worldwide accepted ventilator designed especially with the smallest patients in mind.
FORUMSView All (3)
1Reply10 years ago | drager babylog 8000 what controls the FIO2 in the babylog 8000 infant ventilator Reply |
0Replies11 years ago | circuit assembly Hello, Can you send to me how circuit assembly-viedeo? Thans! Daniela Reply |
1Reply11 years ago | circuit assembly Hello, Please help me understand how the circuit of Dreger baby log is mounted to the mouvies or designs if you repair the face inspired-exhalation.
Thanks Reply |
- Ventilation in harmony with the baby: - Sensitive, accurate synchronization and continuous adaptation features work together to provide the necessary ventilator support, allow optimal levels of spontaneous breathing, facilitate the weaning process and protect the baby from adverse effects such as volutrauma or atelectasis.
- Pressure support ventilation – the standard for neonates: - Drager pressure support ventilation (PSV) features automatic leak compensation and gives the infant more control over the breathing pattern by synchronizing inspiration and expiration. Continuous, automatic leak compensation maintains optimal inspiration times.
- Consistent volume guarantee: - The Volume Guarantee (VG) feature combines the advantages of pressure and volume controlled ventilation. Here, a constant, preset tidal volume is maintained regardless of the strength of spontaneous breathing or changes in respiratory lung conditions. Volume Guarantee ensures sufficient ventilation while avoiding the risk of volutrauma.
- BabyFlow nasal CPAP: - The Drager Babylog 8000 Ventilator plus gives you all the advantages of non-invasive support with an easy to use nasal CPAP system especially designed for the smallest patients. The unique mask design circumvents the pitfalls of the past and enables stable, atraumatic CPAP delivery.
- Easy operation, ergonomic design: - Highly user oriented, a high-visibility monitor displays* your choice of numeric, graphic, real-time or trend data. The combination of user-adjustable monitoring functions and intelligent alarms facilitates workflow and lets the operator concentrate on caring for the baby.
