Burdick - E310
by Burdick
The Burdick E310 has a microprocessor based electrocardiograph
The Burdick E310 has a microprocessor based electrocardiograph, designed to produce accurate records with maximum definition and fidelity. The Burdick E310 also has electrically isolated patient leads for patient safety. A self-check of the micro-processor circuitry is performed each time the unit is turned on. Meets all A.H.A specifications for frequency response and leakage current .
FORUMSView All (9)
-Atmafm
Thu Jun 13 2024
Manual
provide manual
Equipment: burdick E310
-Atmafm
Sat May 18 2024
Ink replacement
how to add ink to Burdick E310
Equipment: Burdick E310
-Cybex
Wed Mar 29 2017
Problem
My machine screen keep reading out of orderReply
        Normal         0                                             false         false         false                  EN-US         X-NONE         X-NONE        MicrosoftInternetExplorer4        /* Style Definitions */         table.MsoNormalTable         {mso-style-name:"Table Normal";         mso-tstyle-rowband-size:0;         mso-tstyle-colband-size:0;         mso-style-noshow:yes;         mso-style-priority:99;         mso-style-qformat:yes;         mso-style-parent:"";         mso-padding-alt:0in 5.4pt 0in 5.4pt;         mso-para-margin:0in;         mso-para-margin-bottom:.0001pt;         mso-pagination:widow-orphan;         font-size:11.0pt;         font-family:"Calibri","sans-serif";         mso-ascii-font-family:Calibri;         mso-ascii-theme-font:minor-latin;         mso-fareast-font-family:"Times New Roman";         mso-fareast-theme-font:minor-fareast;         mso-hansi-font-family:Calibri;         mso-hansi-theme-font:minor-latin;         mso-bidi-font-family:"Times New Roman";         mso-bidi-theme-font:minor-bidi;}                           3-channel EKG microprocessor based                  Touch pad controlled         Resting EKG usage only         No monitor hook-up         Operator initiated self-test         Recording format: automatic or manual operation         Automatic lead marking printhead         Selectable sensitivities:         limb x 1/2, x1, x2         Chest x 1/2, x1         Recording paper.          Writer: galvo and heated stylus (analog); selectable frequency response (filter in/out); two-speed paper drive 1) 25 mm/sec and 2) 50 mm/sec         Power requirements: 120/240 vac 50/60 hz
EKG/ECG TypeRest
Height12 in
Length 18 in
Weight23 lbs
Width15 in
