EPPENDORF - 5415 C
by EPPENDORF
A compact Centrifuge that can reach its maximum speed in only 10 seconds.
The Eppendorf 5415C is microprocessor controlled and has safety switch and safety lock to keep you protected while operating this model. The 18 place 45 degree fixed angle rotor F-45-18-11 is included.
FORUMSView All (7)
-grrvmarndarn_6868
9 months ago
No enciende
Me gustaría obtener el manual del servicio de esta centrífuga para asi resolver el problema, el cual sospécho del trasnformador, sin embargo quiero estar seguro del diagnódstico para no generar un gasto innecesario al laboratorio el cualñ represento. Gracias. Mi correo grrvmarndarn@gmail.com
Equipment: eppendorf centrifuge 5415 C
-kevin.vinton.hb_2275
2 years ago
Calibration
Can this model be calibrated with a tachoReply
31
-Larbsarb
5 years ago
Service Manual
Where can I find the service manual for this? Thanks.Reply
Height28 cm
Length 28.5 cm
OrientationBenchtop
Weight6.5 kg
Maximum Speed14000 rpm
Width21 cm
