HELMER - UltraCW
Provides easy, automatic cell washing for consistent and reproducible results every time.The UltraCW® is designed in accordance with American Association of Blood Bank (AABB) guidelines, the UltraCW is ideal for applications such as blood typing, cross matching, ABO compatibility, Rh testing, Coombs testing, and antibody identification and screening. With complete programming flexibility and superior design, the UltraCW provides precise and time-saving performance.
0Replies2 years ago | Error ser I/O 31 I checked the service manual and it said that this error means that a connection in the frequency converter circuit is loose. I checked all the connections and they all seemed to be fine. Do I need to replace the board at this point? Reply |
3Replies7 years ago | Blood bank cell washer centrifuge hi all, what is the part no. of isolation transformer primary 220vac secondary 110 v ac. shajahan qatarReply |
- Electronic flow meter for consistent, reproducible results
- Programming flexibility for optimized results
- Shorter wash cycles for faster results
- Digital calibration for accurate saline volume
- 24-place rotor option for increased capacity
- Lower height profile on bench
- Saline can be stored below cell washer
- Electronic flow meter provides precise saline fills versus flow timers
- Digital calibration provides easy and accurate control of saline volumes while eliminating time-consuming and cumbersome manual calibration
- Peristaltic pump allows saline supply to be located above or below the UltraCW
Simple To Program - Convenient touchpad with easy to read digital LCD display provides process information, programming prompts, error messages, as well as time and wash status
- Audible and visual end of process alerts
Time Saving Performance - Increase productivity and turnaround times with faster wash cycles
- Save 14 seconds/cycle, 1 minute/wash and 1 hour/60 washes
Twice The Capacity With Optional 24-Place Rotor - Increase productivity by washing up to 24 tubes at once
- Complete antibody identification with only one run
Unique Rotor Design - Eliminates conventional plunger valve and associated bowl cleaning steps
- Innovative design locks tubes in place while the rotor spins in the opposite direction for decant steps
- Rotors accept either 10 x 75mm or 12 x 75mm standard tubes
Consistent Reproducible Results
Height | 22.5 in |
Length | 15.5 in |
Orientation | Benchtop |
Weight | 51.5 lbs |
Centrifuge Type | Cell Washer |
Maximum Speed | 3500 rpm |
Width | 13 in |
