Heraeus - Megafuge 1.0R
The Heraeus Megafuge 1.0R is a refrigerated tabletop centrifuge.The Megafuge 1.0R offers brushless induction drive, quick run, and soft-start/soft brake. You will find this model user-friendly with its microprocessor controls and LED displays (rcf, rpm, time and temperature). This model does not include a rotor. Recommended rotors for this model are the swinging bucket rotor 4 x 400 mL, microtube rotor 18 x 1.5-2.0 mL, Sealed rotor 4 x 150 mL, and the aluminum/hermetic fixed angle rotor 18 x 1.5/2.0.
FORUMSView All (12)
3Replies2 years ago | Moving a Heraeus Megafuge 1.0R - rotor exchange? Hello, my lab has a Heraeus Megafuge 1.0R that we need to move to a new building. Should I try to remove the rotor before moving? If so, where can I find instructions to do so? I downloaded the User Manual, but instructions for Rotor Exchange are missing. ThanksReply |
4Replies2 years ago | Lid error Hello, I have a Megafuge 1.0 that opens and closes perfectly when it is on standby. When you start the cycle, "LID" appears on the screen and remains blocked. The closure system is tested and correct. Any suggestion? Thanks.Reply |
0Replies2 years ago | Centrifuge Megafifuge 1.0 Hello! Help with the Megafuge 1.0 R centrifuge, it gives an error E003, I started to figure it out. Two power transistors, four optocouplers, resistors, a zener diode burned out. How would I find everything, but only one. I did not find IXGH10N60A transistors and installed other IXGH50N60A. Still won't launch. The engine was tested for breakdown. And the 74HC14d chip also burned out, there is no Q1 transistor on the board, help me figure it out or a circuit for this centrifuge? (witemonah@mail.ru)Reply |
Height | 39 cm |
Length | 55.7 cm |
Orientation | Benchtop |
Weight | 104 kg |
Maximum Speed | 6000 rpm |
Width | 70.5 cm |
Timer: 1 - 99 min
Refrigerated: Yes
Electrical: 120V / 60Hz / 11.5A
Operating temperature: 0 to +40 C
