Iris International - StatSpin Express 2
Primary Tube Centrifuge.High productivity, improved safety and lower cost-per-test for the clinical lab. Here’s the perfect solution to sample prep bottlenecks in the busy clinical lab... the new StatSpin Express 2. This amazingly compact and quiet centrifuge spins standard 5 mL blood collection tubes in only two minutes, yet it produces quality serum or plasma equal to 10-15 minute runs in larger, more costly equipment. Best of all, the Express 2 is small and quiet enough to be used where it’s needed most - right at the workstation. The two minute automatic cycle combined with rapid, gentle deceleration make the Express 2 the most productive small centrifuge available. Tubes are processed as they arrive - no waiting for batches.
FORUMSView All (3)
3Replies3 years ago | Ramp up/down times Does anyone know the ramp up/down time in seconds for the StatSpin2? Reply |
1Reply4 years ago | How to clear the red gear light? PM Cycle. Can anyone provide the procedure for clearing the red gear light? Reply |
2Replies7 years ago | Stop spinning Device intermittently stops spinning with 180s flashing, then 30s will flash on subsequent attempts.Reply |
Height | 6 in |
Length | 8.6 in |
Orientation | Benchtop |
Weight | 5 lbs |
Centrifuge Type | Clinical |
Maximum Speed | 8500 rpm |
Width | 6.6 in |
[list] Power Requirements: 24VDC 1.7A Cycle Options: 30s(quick), 120s(norm), 180s(hard) Cycle Times: 30, 120 and 180 seconds Acceleration Time: 20 seconds to 95% of speed Deceleration Time: Less than 30 seconds Tube Sizes: 1.5 to 5.0 mL [/list]
